configure dos-protect trusted ports
configure dos-protect trusted-ports [ports [ports | all] | add-ports [ports-to-add | all] | delete-ports [ports-to-delete | all]]
Description
Configures the list of trusted ports.
Syntax Description
ports
Specifies the trusted ports list.
ports-to-add
Specifies the ports to add to the trusted ports list.
all
Specifies all the ports.
ports-to-delete
Specifies the ports to delete from the trusted ports list.
Default
N/A.
Usage Guidelines
Traffic from trusted ports will be ignored when DoS protect counts the packets to the CPU. If we know that a machine connected to a certain port on the switch is a safe "trusted" machine, and we know that we will not get a DoS attack from that machine, the port to which this machine is connected can be configured as a trusted port, even though a large amount of traffic is going through this port.
This example sets the trusted port list to 3:1-3:7:
configure dos-protect trusted-ports ports 3:1-3:7
This example adds the trusted port 3:8 to the current list (use this command with a network administrator machine not connected to the internet that is attached to port 3:8):
configure dos-protect trusted-ports add-ports 3:8
This command was first available in ExtremeXOS 11.1.
Platform Availability
